When trying to reduce the number of identical components from the system this version could not be removed as log messages where still in the memory-buffer target.
This could cause problems for filtering, and you can either stop/start the log server, or the specific application using the component (after you did a "clear log"). See compClients for information on how to obtain the component owner.
Error
Component \"%component%\" v%formatVer%.%contentVer% could not be removed, as it has pending log messages.
| Name | Type |
| component | String |
| formatVer | uInt |
| contentVer | uInt |
